Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Steam Engines
Steam Engines Discuss your live steam engine creations here!
Old 04-07-2007, 03:37 AM
gilessim is on a distinguished road
problem drilling tiny holes
Hi there,I have to drill several rows of 1mm holes ,5mm deep in brass and no matter how well I set up the piece in the mill (with a lazer center finder) the drill bit wanders!. I need to somehow centerpunch my marks ,I guess I could use a finely ground punch in the mill ,and just press down lightly ,but does anyone know of an easier way? by the way, check out this guy! http://www.barryjordan.freeola.com/
Old 04-07-2007, 04:57 AM
Stepper Monkey is on a distinguished road
If not a centerpunch, try a ball mill or bur to start the hole. If you don't think they make 0.9mm, 0.7mm, 0.5mm and smaller ball mills, go ask your dentist for his old ones. They used to sterilize and reuse bits until they got dull, but they aren't allowed to reuse on patients anymore. Every little cavity and a new 3/32" shank carbide bit goes in the trash with only seconds of use on it.
Ask him to save up and autoclave (sterilize) his old ones for you instead of trashing them and a week or two later you should have a lifetime supply to play with, even if you live a very long time!
Old 04-07-2007, 08:33 AM
bogstandard is on a distinguished road
Just buy yourself the smallest centre drill (slocombe drill) and just touch on, this will give you a detent to start your drill. The reason you want to touch on is I think that the smallest tip point is 1.6mm, you just need to create a small detent to keep your drill straight. Also at this size you need to have your drill press or miller running the fastest it will go otherwise you might find you are breaking drills. Using this method I have no problems drilling as small as 0.2mm.
Old 04-07-2007, 01:26 PM
2muchstuff is on a distinguished road
Lab burrs have a 3/32" shank diameter, high speed handpiece burr shanks are 1/16" in diameter. I work in the dental field and dentists still sterize and re-use thier burrs until they get too dull to cut thru tooth enamel, then they throw them away. I see it done day after day in numerous offices. They are still plenty sharp enough to do what you want them to do. You can get new ones for about a dollar each thru a dental supply.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 04-07-2007, 01:36 PM
drk drk is offline
drk is on a distinguished road
You could always try some carbide pcb drills, the shank would be 1/8 inch and sizes start from 0.3mm
Old 05-23-2007, 11:33 AM
centre drills
Thanks guys, I did find some centre bits with 0.9 mm points on them ,I bought them from some polish people who sometimes sell stuff on the side of the road here in Italy, they seem to be solid carbide ,and I already broke one tip!, they have resolved my problem ,and luckily I bought a few (50 cents a piece!) they have 5 mm shanks and must be made in Russia ,but do the job!....thanks again..Giles
Old 05-26-2009, 04:03 PM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
I think NASA used to just have tiny holes put in using EDM machines, no tool pressure and perfect holes, just make the trode undersized!
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
Old 05-26-2009, 05:04 PM
AMCjeepCJ's Avatar
I should add that these holes were in the .003"-.006" range and they made the electrodes by using the EDM too. No tool pressure, no bending~ I only remembered this because the guy who had the job made a bundle of money because no one could figure out how he made such perfect, tiny holes exactly on location... Now the whole world will know, lol... He's retired now and out of the machine industry so it's not a big deal to share anymore and besides, this was several decades ago and those types of holes aren't a big deal any longer but it is a cool way to make tiny shallow holes precisely if you are having trouble drilling them~
Drilling very small holes William Demuth CNCzone Club House 7 12-21-2008 03:56 PM
Drilling holes wildcat General Metalwork Discussion 18 01-31-2007 09:38 PM
drilling holes WOODKNACK SheetCam 1 11-30-2006 08:10 PM
drilling 5000 3mm holes barnesy General Metalwork Discussion 4 08-23-2006 05:39 AM
bits for drilling holes posix WoodWorking 4 03-09-2006 11:41 AM
