Maybe I have a different way of understanding things than other people but those CNC wiring diagrams just don't explain anything without additional words to clarify. The wiring diagrams I understand show wires going between devices I can identify with specific info on which screw terminals they connect to on each.
To me, that top image shows four seperate ground wires going out from four seperate points to four seperate ground screws that aren't on either the VFD, the spindle or any of the plugs. It doesn't seem to say what those ground screws are connected to.
It also seems to show 4 wires going in to the VFD from the wall outlet for power.
When I asked here about where the wires connect to, I was told:
- There are just two wires going into the VFD for power (two hot) and if there is a third wire on the cord, it should not be connected to anything
- There are four wires (shielded) going from the VFD to the spindle. 3 hot going from u, v, w to u, v, w and one going from ground on the VFD to ground on the spindle
and that is it (assuming the spindle will be controlled by the VFD and not by Mach3 or Linux CNC). Is this not correct? Do I need additional wires going from the cable shielding to a seperate device? Or is there more than one wire from ground on the spindle or ground on the VFD?
