Rfom the manual:
So your diagram is right regarding your VFD, the only thing which is not clear in your diagram is the earth. The earth connections on both ends of your schematic VFD should be on the same bar inside the VFD and that should be the same as the earth in your home AC plug, coming from your power cable to the VFD. BTW, you have 230V in Denmark...If it is single phase model, please select any of the two input power terminals in main circuit power.
