Originally Posted by
mactec54
I don't think there is any numbers that have been posted, I have always used 40Ft lbs. on the top nut and small dab of ( one spot ) Loctite, the bottom nut 40 to 60Ft lbs. this depends on the threads in the nut, some have good threads, some are just plain bad threads, the bottom nut is something you can check to see if it is tight after running it, so start low and add a higher torque if it need to be retightened after some use, here is a photo of one of my Pin wrenches, I could not find a photo of the top nut wrench
