Perske bearing change
Results 1 to 3 of 3
Thread: Perske bearing change
    Nov 2007
    canada
    Default Perske bearing change
    I have my perske spindle stripped down for a bearing change and the only way I can see to get to the lower bearing is to press the rotor off the shaft. I paid to have the bearings changed 2 years ago and I can see an alignment mark engraved into the shaft and rotor, which also leads me to believe this is the correct course of action. Anyone have experience with this? How hot should I heat the rotor before I attempt to press it off? Thanks for any input.
    Attached Thumbnails Attached Thumbnails Perske bearing change-img_2212-1-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Perske bearing change
    A bearing puller won't pull it off?
    UCCNC 2017 Screenset
    Nov 2007
    canada
    The bearing I need to change is in the black housing on the collet end. The bearing you can see on the other end isn't an issue.
    Thanks for your input
