I understand all of that completely. I said a 0
.25HP drive won't run a 3
.0HP motor. See the decimal points? They are important, as are periods
. Maybe you read too quickly and misinterpreted.
I only wanted to correct your post #5. You wrote that all E series the drives are the same inside and will run any motor up to the max motor size for single phase. That is clearly false as you just now explained. Maybe you did not mean it that way but your writing style seems a bit too rushed to be clear. Just like the Chinese label writers.
