4-Pin Cable Female Connector, Stepper Motor Connector 3A / 40V.
https://www.aliexpress.com/item/Farr...StoreLevelAB=5
or you can solder a shielded wire directly on the male connector itself, it`s cheaper that way and more resistant to connector power loss if that`s mine I wont bother buying a connector on that one, I will solder the shielded wires directly on the connectors itself, put some RTV silicone and voila! more rigid than any connector on earth
