Hi, why have you not connected the 12-24V to the bob?
I matched the ones in the pdf. According to the pdf it appears to say that to use p1 for pwm but there is a pin place for pwm on the bottom of the Bob so it's confusing. Using p1 in mach3 doesn't do anything.
Does the wiring for the Estop look correct? If I use p10 and join the two wires it does not stop. All of the settings for mach3 were taken from the PDF. My axis work fine.
The motor tuning is set but it could be wrong. Are there suggested settings?
Sorry to be a pain but I've spent hours trying to sort this myself.
Sent from my SM-G935F using Tapatalk
I didn't know that I had to. I'm just a cnc user trying to get this to work. The builder has no customer service and dropped me in it..... #steeplearningcurve
Will the Estop and spindle speed from mach3 not work without it?
What do I need to connect and where to?
Terminal 12 and 20?
Thanks Jase
I am not talking about the VFD terminals. You have to connect either 12V or 24V to the breakout board, look at the image of the BOB where it says 12-24V pwm/limit switches. Just under the relay connection. They all highlighted with a red block around them. This 12/24V supplies the BOB with voltage to be able to source your 0-10V for the VFD speed reference and the limit switch power/signal.
The connections you made between your VFD and BOB are all correct...
Ericks, please bear with me. As I stated I did not build this machine. The builder doesn't want to help....so I'm trying to learn fast!
If I wire the two empty terminals on the right of the Bob to 12 and 20 of the vfd will that supply the 12/24v required?
Thanks Jase
No worries .....you could take the power from your VFD, personally try not to do that. Don't you have either 12V or 24V in your control panel?
The reason i don't use the VFD psu for external devices is that if you get a short somewhere, that could damage your drive....
Or I guess I could take 12v from the pc power supply?
Sorry for the delay, i came off night shift and went to bed. That little psu might be what you require, if it doesn't have specs written on it then either measure the output or check where the output cables are going to.
Maybe a fan??
If you use the VFD 24V then best you install a fuse to protect the VFD against possible external shorts....
I had a quick look at your VFD manual....you are able to "read" the incoming 0-10V from your bob and display it on your VFD display, nice feature if you don't have a multi meter...so you can actually see the frequency ref from Mach3 via your bob
12V from pc psu should be okay...
I get frustrated not knowing this stuff but love reading and learning. It's great having guys like you who are willing to help.
I'm having no help from Danfoss regarding vfd parameters. I can get it to show that an external pot is being read but it doesn't alter the spindle speed. The on-board pot works. Is there a parameter that needs to be set to accept commands from a analogue input? I even wired an Estop and that doesn't work either.
Drives require you to "tell" them the source of the start signal....keypad or terminal etc...
Next it requires you to set the frequency ref point...either the keypad/on board pot or external 4-20mA or external 0-10V.
These analog speed ref inputs are also able to be scaled by parameters, giving you flexibility...
I will check the speed ref parameters required for your application. Meantime you should connect the 12 or 24 V power to your bob...
Give me a little time....just going out for a couple of hours, then i will help you
Will also show you how to set up your drive to see the analog value for testing purposes....
Hi....so you have connected from your bob to 53?
No prob. Ill get a dedicated supply if need be. Ill try using the pc 12v supply first. I think the little supply in the box is supplying 5v and not 12. What output supply should I look at getting?
I've been finishing some DIY. Going to take a look this afternoon.....before collecting the kids.
