Is this a 20krpm spindle?
If so you most likely had the minimum rpm setting to low.
Inconfiguring a new vector Huanyang VFD model GT-2R2G-2 for a 2.2 kw spindle (8.5amps FLA) air cooled. What would be the best settings (meaning codes) for thisapplication, this is a diy 3 axis mill intending to do mostly light allu, brassand wood. I would like if some one could help me to config this vector VFD since Ismoke my previous Huanyang model HY02D223B, tank you and have nice charismasholydays.
Mactec54
Thank you for your quic response my spindle is a max 400 Hz 220v 3ph again will appreciate all the infos you can give me.
Here is some Parameters to get you going, there will be some other Parameters to set, that will depend how you are going to control the VFD
P0.03=200
P0.04=400
P011=10 ( adjustable )
P012=10 ( adjustable )
P014= 6 ( 6 to 8 )
P1.01=10
P1.02=20
P2.01-2.2
P2.02=400
P2.03=24000
P2.04=220
P2.05=9.5
Once these Parameters are set, you can then do a Autotune, you set Parameter P016=1 and Press Run
For main wiring connect R Hot T Hot and Ground to the Ground Terminal, this is your connection for NA 240v single Phase
Mactec54
