Good idea about the Ethernet cable, why didn't I think of that. I already have a spare one long enough. I've had to leave it now for today so will get that wired in tomorrow.
On grounding the shield I was under the impression that only one end should ever be earthed to protect a signal cable?
I don't think Mach3 or the USB converter are the issue. Everything was fine separately with no issue until I wrote the brain and tried to use them all together with normal spindle commands, then the problems started.
Writing commands still works despite the CRC error. In modbus test I can turn the spindle on and off, CW and CCW (just to test) and set the frequency to anything and it all works, only the inputs don't work now and cause a crash when tried to use except in modbus test it doesn't crash, it just doesn't do anything and tells me there's a CRC error.
I already changed the spindle on/off and frequency to be in the same config. It works absolutely fine with the spindle dro button, m3, s*****, m5 all works as it should.
