Hi I am on the last leg putting together a DIY router table this is my first time with anything remotely like building a cnc router. I have a HY series VFD and matched water cooled spindle 2.2kw. However the VFD is made by Isacon Control Tech. Co. Ltd. first has anyone used this unit and can help me with the setup VFD to Breakout board and Mach3 to breakout board. The VFD unit has only16 control ports.my breakout board provides a 0-10volt speed regulation pin and a ground which seems to connect with the Isacon VFD Via ports 5 & 6 respectively. I believe the grnd must be kept separate from other uses and that means I am unsure how to wire a start-up control. Unfortunately this unit is sufficiently different from the standard HY series shown on youtube to make life difficult any help would be appreciated.
