Reyann Cheap Chinese VFD
Results 1 to 4 of 4
Thread: Reyann Cheap Chinese VFD
    Mar 2013
    United Kingdom
    Default Reyann Cheap Chinese VFD
    So I've come across the Reyann brand of VFD on Aliexpress, on the face of it they look good and have great reviews. I'm just curious if anyone on here has any experience with these?
    There isn't a ton of information out there on these VFDs, they're a little more expensive than the Huanyang VFDs but supposedly have more features too such as Sensor-less Vector Control.
    Currently $117
    https://www.aliexpress.com/item/2-2k...c1ec6989&tpp=1
    Member mactec54's Avatar
    Jan 2005
    Default Re: Reyann Cheap Chinese VFD
    Quote Originally Posted by Fenza CNC View Post
    Currently $117
    It only has a 10A rating, which is not enough for a 2.2Kw spindle, you want a VFD Drive to have at least 13A to 15A rating for a 2.2KW spindle, higher the better, for single phase use
    Mactec54
    Mar 2013
    United Kingdom
    So the 2.2kW Chinese spindles need a 3kW VFD?
    Jan 2005
    Just depends on the quality of the VFD Drive, 1hp to 2Hp more then the motor being used, is a good general rule, to stick too, this is not just for Chinese Spindles, it's for any AC 3phase motors that you want to run with a VFD Drive, on Single Phase
    Mactec54
