If you are using Mach 3,, then be sure and set you correct pulley ratio. Kinda sounds like that setting is wrong!
Hope this helps.
Bill
PS. Sorry I don't have a Huanyang VFD so I can't speak to settings there.
Well I have had some success getting my spindle working better with Mach3
The actual RPM on the mill is 3 X more them the RPM in Mach3, I assume this is a parameter setting in the VFD
Does any know which setting and how to fix it?
- New Machine Build- E.OC.A on Huanyang VFD 2.2 Kw
- Need Help!- Huanyang VFD - again
- Need Help!- Huanyang 2.2kW VFD.
- Huanyang VFD
Hope this helps.
Bill
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
I use mach 4 so what other poster said too - Check parameter / line 0144 in VFD settings for spindle max.
Much more on this vfd here
http://www.cnczone.com/forums/spindl...gs-manual.html
