Hi, I am new to the group and I am having issues with my new spindle. I had it running then it popped and stopped spinning. I now get the EOCA error, I have tried resetting and re inputting the the parameters. Can anyone help me to ensure I have the right parameters set.
Thank you.
Mactec54
It's wired to plug into a normal socket. It's the HY01D511B single phase 110v 50hz. I had it running then there was a pop and it stopped. I followed the book, and then tried one of your earlier posts. I am hoping that the spindle is not fried, or it's just a resistor. I bought it from next wave automation.
Following the manual, most don't get it right, it won't be a resistor, I have to know more on how you have wired the VFD as this is important
It could be either the spindle or the VFD that has failed, from what parameters you set will give me an idea what may have happened, so need to know what Parameters you set
Mactec54
110 Volt VFD & Spindle Setup
Function Code Value
Front Panel Operation PD001 0
Front Panel Knob PD002 1
main Frequency PD003 400
Base Frequency PD004 400
Max Frequency PD005 400
Intermediate Frequency PD006 2.5
min Frequency PD007 10
Max voltage PD008 110
Intermediate Voltage PD009 15
Min Voltage PD010 8
Frequency Lower Limit PD011 60
Acceleration Time PD014 3
Deceleration Time PD015 5
Analog Input PD070 1
Analog Filter PD071 20
Lower Analog Frequency PD072 400
Higher Analog Frequency PD073 60
Rated Motor Voltage PD141 110
Rated Motor Current PD142 5
Motor Poles PD143 2
Rated Motor RPM PD144 3000
PD007=20
PD014 is to low 10 is a good starting point
PD015 is to low also
These spindles can not run below 6000 RPM PD011 you have at 60, 100 is the minimum they can be set at, to be safe they should be set at 120 the same with PD73=120 safe
The Parameters look ok except for the minimum RPM, and the Acceleration, Deceleration, not setting the minimum RPM correctly is a fail waiting to happen, this usually damages the spindle
Check with your meter the spindle windings
Pin 1 to Pin 2
Pin 2 to Pin 3
Pin 3 to Pin 1
And then all to Ground, do you have the Ground attached to Pin 4 and check that Pin 4 is Grounded to the Spindle Body
How do you have the input wiring connected to the VFD
Mactec54
Did you ever get it running? Mine just got delivered but I don't have a clue how to wire it for 110v. Even though there is a sticker on the from of the vfd the manual only shows how to wire it for 220.
Do you have a wiring diagram you could share? Thanks, rick
Thanks amigo, I think I have all I need now to wire it.
