- Simphoenix E500 VFD
Simphoenix E500 VFD
Hi Guys,
I'm from New Zealand and i work in the composite industry and i currently have a x2 tormach 1100 mills and one of my work customers has recently sent me x2 probotix comet bench top router tables.
I'm having some issues with setting up the parameters in the VFD on the routers ( im very new to the world of DIY kit CNC routers ) i was told that the parameters were set from probotix but this is not the case.
Spindle specs are as follows - 2.2kw - 220v - 8.5a - 400 hz
Could anyone please guide me in the right direction on setting this system up ? Ideally i would like Linux cnc to control the spindle speed/start and stop but i would be happy with just using the run button on the VFD.
Will
- You may not post replies
- You may not edit your posts
Forum Rules
