I had a Chinese built 6040 router that came supplied to run on 120 volts with a 120 volt VFD. It ran great, no issues but I was not going to cut 3/4 inch plywood with one pass ether.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Most modern homes wired to Code the outlets are wired for 20 amps, check your circuit breaker panel for more information. Frankly I do not know what a 1.5 Kw spindle on 120 volts would draw. I know my 2.2 Kw VFD calls for a 30 amp breaker on 240 volts single phase. The larger spindles are not practical on 120 vac.
You won't be using 30A on a 120v supply with a 25A Breaker you most likely won't go much of the 20A If you have changed your mind and are running a 240v circuit then I would go with the 8 Gauge 2 Hot Neutral and Ground that way you can have a 120v circuit and a 240V circuit from the same supply
These are the best type of Plugs for these type of connections, if you are going to a cabinet the you need a disconnect at the cabinet
This can be a 4 wire to your cabinet and then you can have 120v and 240v for your cabinet supply
You would need a 4 prong Plug if you use a 4 wire supply
Mactec54
Thanks again mactec54, appreciate all the help! Trying to do all my research before I buy anything.
I haven't changed my mind. I'll be running 10/3 Romex to the VFD, and then 16/4 double shielded from the VFD to the 1.5kw spindle.
Yes this will be permanent in wall install with cable run inside conduit.
I'll then use a cable like you see used on a stove and use that to connect from the wall outlet to the VFD.
The Shielded Cable from the VFD to the Spindle does not have to be 16 Gauge but that will work
CF6-15-04 is a IGUS cable which is as good as it gets this is 16 Gauge 18A Rating
CF6-10-04 is 17 Gauge with a 15A Rating
CF6-07-04 is 18 Gauge with a 12A Rating
Mactec54
I was going to use a disconnect switch next to the outlet, possibly this one;
https://www.amazon.com/gp/product/B0...A3VRYS8E&psc=1
or this one;
https://www.amazon.com/Woodstock-D41...QTNWHK6GDYPMV8
I am am looking into using a UPS to filter the power, as well as building a positive pressure filtered enclosure for the VFD.
No you would not want to use a UPS for a VFD Drive supply, the Filter I posted is what should be used , if your outlet has a box big enough you could put the Filter in that box or if you have a machine cabinet that is the best place for the Filter and closer to the VFD Drive
Yes they would work which one would depend on what you are mounting on the wall Ideal a disconnect is like the snip below and is mounted at the control cabinet, there are many types of disconnect switches that could be used
Mactec54
Here is one of many suppliers https://www.digikey.com/product-deta...30L-ND/2136855
Most are using this Filter or one similar
Mactec54
Here's the link;
Concepts of Signal Noise Reduction - Shielding and Grounding
The entire manual is a good read. See page 22;
Whether I use the UPS or not I will still use the one you posted a link to.
It installs right before the disconnect and receptacle correct?
