You don't wire romex directly to the VFD.Plan to use a dedicated 20 amp 2-pole breaker from my panel in shop and connect to VFD using standard 14 gauge 2 plus ground Romex.
Where are you putting the VFD? If it's in a control box, it would normally draw power from the control box source. Otherwise, make a cord to plug into your 240V outlet, and wire the cord to the VFD.
Some will say to ground the shield only at the VFD end, some will say both.
Igus CF35-15-04 is what I'm using.
There are two Huanyang Modbus plugins for Mach3, This is the easiest way to control the spindle. Costs about $10 for a USB > RS485 converter.3- I do not plan to run the VFD in manual with a Pot but will run via mach 3. Here is where I need advise. What is the BEST way to do this. The Mach 3 manual states the three methods as:Relay/contactor, Step & Direction or pulse width modulated. What ever is the best a wiring diagram or pictures would be great or both! Also a detailed step by step instructions.
Next method would be PWM. But you need a PWM to 0-10V speed control board, unless your breakout board already has one.
Depends on how you are controlling it.4- Going thru the Mach 3 setup is always a battle as I am stupid so again guidance on the Spindle setup tab of the Ports and Pins would be great! There are a lot of boxes to click or not plus valve inputs.
Spindle NOT connected when you first fire it up and configure it. And don't plug the spindle in until the power has been off for at least a minute.5- Knowing the exact model of VFD/Spindle the complete list of VFD parameters to set would be much appreciated. Commissioning instructions also would be great.Spindle connected or not during 1st powering of VFD? Please advise
See the posts from Mactec for the proper parameters. I don't have a list handy.
Depends on how you are controlling it. With PWM, set your PWN Min % to 33.7- How do I ensure I do not run the spindle to slow, "below 8000rpm". I'm fuzzy on this issue?
I'd put it in the control box, if you have room. Otherwise, it should go in it's own metal box, with filtered fan input and output.8- Environment issues with VFD. Again we go to great lengths to keep dust and dirt away from VC's at work. Filter media on cooling fan inlets. I plan to build some kind of enclosure with a glass window to view the VFD. Door seal, cooling fan, etc. Anybody have pictures of designs they have come up with?
