- China CNC 3040T 4 Axis and Spindle Control with PWM and Mach3
Hello,
i bought this CNC Router:
https://www.amazon.de/gp/product/B01...?ie=UTF8&psc=1
inside is this Controller:
New CNC Router 3 Axis TB6560 3A Stepper Motor Driver Board Mach 3 | eBay
and for the Spindle Control is this litle board inside the Control Box:
jp-1482
https://bleughbleugh.wordpress.com/2...spindle-board/
Now, the main Goal is to control the spindle via Mach3.
Is that possible?
On the 3 Axis Controller post is a Output for a PWM Signal. On the Board is also a Jumper where you cn turn on the PWM Control.
At the litle board, which controls the Spindle at the Moment via a Manual Rotary potentiometer, is also a connector, but this is
callded "PMW" iso "PWM" ???
I am not sure how to connect the Wires between the TB6560 and the Little JP-1482 Board?
Can anyone help me out here ?
Matthias
Re: China CNC 3040T 4 Axis and Spindle Control with PWM and Mach3
Hello,
i now bought an PWM Speed Controller from eBay:
https://www.ebay.de/itm/PWM-Speed-Co...53.m1438.l2649
In Mach3 i have set up the Pins and i can now turn on and off the spindle. I can also control the Spindle Speed, but not
from 0-12000rpm as my Spindle can have. It seams there is anything wrong with the Spindle Pulley Setup or the PWM frequency in Mach3.
But i dont know what i have to set here.
Can anyone help here please ?
Matthias
Activation process
Activation process
Activation process
Here is a link to a video I did on how to wire it up
I posted this a while ago but the admins didn't approve my message
- You may not post replies
- You may not edit your posts
Forum Rules
