Originally Posted by
cjgomes
Hi everyone,
I have been building my home-made CNC machine for some time. I own an hy02d223b VFD and a GDZ-80-2.2B spindle (220V, 2.2kW, 400 Hz, 24000 rpm). To make it short, I installed the spindle and set up the VFD last year. It worked fine (just testing the setting and such). The VFD even worked with the 10 Volts input for controlling rpm and RUN button. Everything was fine, or so I thought.
After letting the CNC aside for a few months, I retaked it again a couple of weeks ago. The problem is that, now, the VFD is giving me the error E.ov.A (Error: Over Voltage at Acceleration) over and over again. The spindle seems to try to rotate when the RUN button is pushed, but it stops and the error shows.
I used the factory default (PD013=8) then setted the PD005, PD004 = 400. Verified PD008 = 220. The PD141, PD142, PD143 and PD144 were set to the spindle specifications
Thanks for the help
