- Need Help!- Chinese spindle 2.2 kW funny noise
Hi there,
I just installed a new spindle, 2.2 kW water cooled, Chinese.
Before using it I made it run at low speed for 2 hours and then increased the speed gradually.
I have a funny noise between 8000 and 24000 RPM which comes and goes with and without load on the spindle.
I have recorded it
There are no vibrations on the spindle and I have no idea if this could be a bearing issue.
What do you think? Is it faulty?
Re: Chinese spindle 2.2 kW funny noise
Sounds like an outer race spinning. Not good.
Sent from my SM-T813 using Tapatalk
Gold Member
It also sounds like fluid bubbling. Does that sound change at different speeds?
- You may not post replies
- You may not edit your posts
Forum Rules
