- SUNFAR E300 FROZEN.
SUNFAR E300 FROZEN.
I have a sunfar e300 vfd. my problem is the vfd will not allow me to enter most of the numbers I need. I have found only one reference to reset it. it is in the manual under trouble/reset. I know that on my other vfd you can go to pd013 and enter 8 to reset. not the case here. briefly it says to close external multifunction terminal and cm then cutoff. the external function I see is the x1, x2, x3 terminals. problem is I have never connected them, so how do I perform this. another problem I see is pd 0.0 and pd0.2 are set for external keypad. for the time being I just want to use the vfd keypad. the other option is to use rs485 setup. I do not want to go there. the vfd comes on but does not operate the spindle. I would be glad to hear from any knowledgeable person about this. this all started from changing my bb.
Re: SUNFAR E300 FROZEN.
Hello, I'm only new to this but I could be able to help......
There should be f numbers if it's a e300 not pd numbers.
F0.0- should be 3 to give you speed control on the keypad on vfd
F0.2- should be 1000 to start and stop from keypad on vfd
And to reset if an error code comes up (fu.40) press start stop button on vfd
Or turn power off wait ten seconds and restart
Hope that helps
THANKS FOR THE HELP. I WILL GIVE IT A TRY.
- You may not post replies
- You may not edit your posts
Forum Rules
