- Need Help!- Min and Max hz for Yaskawa spindle motor
Hello
Doe anybody know what the min max frequency is for Yaskawa UAASKA-08C.
All it has on data plate is rpm 1500-8000
Ken
Re: Min and Max hz for Yaskawa spindle motor
I know in the SCM machine. When 400hz the spindle rotate until 24000rpm.
Yaskawa VFD's can come with custom software that changes the output frequency range. I'm not saying that it is feasible for you to do this if you buy one (if you manage to do it, please let us know about it), but some companies do this for whatever products they are making.
So you're not necessarily going to figure out what the frequency range is on a used Yaskawa vfd by looking at the part number.
The best way is to figure out what motor it used to drive and how many poles that motor had and then a simple calculation will tell you.
If it's a 4-pole motor, 267ish Hz. If 2-pole, 133ish Hz. the 'ish' is allowing for a few Hz for slip compensation.
f(Hz) = (n_poles/2)*(RPM/60)
- You may not post replies
- You may not edit your posts
Forum Rules
