Router Switch - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Router Switch
  1. #21
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Router Switch
    yes, the existing 24V power supply will work
    with the 3 axis MX3660 printer port pins 1 , 8, 9 & 17 controls the 4 outputs
    (on the 4 axis MX4660 pins 8 & 9 control the 4th axis)
    using two SSR-25DA will give you control of two mains outputs
    you can either tap into the mains supply to your machine control box
    or add another mains inlet wired to the 2 relays and 2 computer controlled mains outlets that you can plug your router into
    in Mach 3 (or 4) you will have to assign the correct pins to control the relays
    John
    PS
    Router Switch-two-mx3660_ssr-connections-mains-supply-jpg
    Last edited by john-100; 05-28-2017 at 07:31 PM. Reason: add to post in responce to post 19 that I initially missed plus PS
  2. #22
    May 2017
    OK, I think it if finally sinking in. It was confusing me with having two SSR's. If all I am interested in is the router, I guess I would only need one SSR, is that correct. The second could be for a vaccum or something like that. As far as the printer port pins, I would set those up to do what I want them to do in Mach3, correct?
  3. #23
    Mar 2007
    uk
    If you only need one relay to control the router then just fit one relay
    John
  4. #24
    Mar 2007
    uk
    Hi
    I don't know what happend yesterday to the 2nd part of my answer but
    on pages 17 & 18 of the MX3660 manual you will see the four outputs you can connect your relays to
    are controlled by the computer printer port output signals on pins 1 , 8 ,9 & 17
    in mach3 (or 4) you will need to set up pins 1 , 8 ,9 & 17 to control the relay(s)
    John
  5. #25
    May 2017
    Roger that. I think I can handle this. If I have anymore questions I will let you know. I GREATLY appreciate your help in this. I went from clueless to actually understanding. Thank you very much. Stacey
Router Switch
Router Switch
