- connection to the spindle?
I have a 2.2kw spindle and I messed up the connector to the spindle. It is a four pin connector that threads onto the spindle. The black insulation portion on the female end is broken and I need to replace it. Anyone have any links to a replacement for this? Ultimately, i'd like to just get the female portion so I don't have to mess with taking the spindle apart and remounting the male portion but If I have to I will. So, anyone have a suggestion with a link?
Thanks!
rockaukum
this is the one i have:
AIR COOLED 2.2KW SPINDLE MOTOR ER20 AND MATCHING 2.2KW INVERTER DRIVE VFD
Re: connection to the spindle?
I think that's a pretty common connector, often called a "microphone connector" for no good reason. Ok, apparently it's a connector used for switchable microphones. You can buy them from electrical houses like digikey or mouser. Look at the data sheet to make sure it's the right size.
I don't know if those connectors come in different diameters, but this one is cheap enough to gamble on.
https://www.radioshack.com/collectio...icrophone-plug
Rob
Sent from my SAMSUNG-SM-G900A using Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
