Startup speed for spindle?
Results 1 to 2 of 2
Thread: Startup speed for spindle?
    Member rockaukum's Avatar
    May 2017
    california
    Default Startup speed for spindle?
    Hey guys,
    I seem to remember reading here about a way to set the Huanyang vfd so when the run command is pressed the spindle will startup and a set speed. Now that I have the spindle running, I can't seem to find the post. So I there a PD setting that will allow a predetermined speed?
    I have the 2.2kw vfd with a Chinese spindle. Currently running the controls via the panel on the vfd.
    Any help would be great!
    Rockaukum
    Member GigaWatt's Avatar
    Apr 2015
    Default Re: Startup speed for spindle?
    Post your question in the Spindles/VFD section of the forum. You will probably get a quicker answer.
