Huanyang 7.5 kw VFD help wiring remote start
Results 1 to 8 of 8
Thread: Huanyang 7.5 kw VFD help wiring remote start
    Registered Tomzar's Avatar
    Jul 2016
    Default Huanyang 7.5 kw VFD help wiring remote start
    Can anyone help me out on this problem? I need to have a remote on off.
    Jun 2003
    Boalsburg PA
    Default Re: Huanyang 7.5 kw VFD help wiring remote start
    you mean pushbuttons, correct?
    You just want to go in one direction?
    What kind of buttons, momentary?
    Jul 2016
    Yes Push buttons. 1 button is ON and the other is OFF. And yes they are Momentary.
    Jul 2016
    I had a 4.0 KW VFD. I had them hooked up to DCM and Forward. Now I went with a Bigger motor so I went with the 7.5 KW VFD.
    Jun 2003
    Boalsburg PA
    my guess is that it is the same. The manual I have goes from 1/3 hp to 75 KW.
    Page 37 in the manual at this link
    Top diagram with run/stop. Ignoring the reverse button, wire it up that same way
    Jul 2016
    Attached Thumbnails Attached Thumbnails Huanyang 7.5 kw VFD help wiring remote start-20170505_163524-jpg   Huanyang 7.5 kw VFD help wiring remote start-manual-jpg
  7. #7
    Dec 2003
    I would hazard a guess that the S1 to S7 is the same as the previous version for the PLC inputs, these would be assigned in the parameters.
    There should be much more in the manual than you show.
    Jun 2003
    Boalsburg PA
    I take it you meant to post different pages rather than many copies of page 12?
    Not sure why they would change the designations. I thought mine was the new version.
