It is very easy to tell if you have a HY VFD or not all the clones / copies use different Parameters sets, and even though they look the same they even have a different name
Yes they have a MCU that controls all the VFD functions, faults Etc, it would not be a VFD drive without a controlling device, such as a CPU or a MCU,
Mactec54
Mactec54
you have been very helpful, thank you. That IGBT part number is for the 4kw version? It turns out my VFD has the same circuit board as the one in the link I gave before A Different Kind of Chinese Motor Controller?! Adding Dynamic Braking to your Inexpensive Chinese VFD | equals zero I didn't see where to put the zeners, but I haven't really disassembled the drive fully, it's still in the cabinet of my lathe. Hopefully I can get my friend to solder the surface mount parts, I don't have much experience with that.
ok, there is a schematic of the 2.2kw version here Huanyang VFD controller plugin
so I think I'm ok on the mods needed. I guess there are no pads for the zeners.
unterhaus ... that is correct there are no pads for the Zener Placement on the Braking IGBT they need to be soldered direct to the IGBT pin pads, they connect the same way as on the schematic of the 2.2kw units.
The IGBT part number and the Optocoupler part numbers I gave you are for the 4KW units as that was the unit you were asking about they are not for the 2.2kw it uses different components.
Mactec54
Interestingly, HuanYang electrical just showed up on Amazon. They use a power module. https://www.amazon.com/dp/B0775DC75F?m=A3A1CXRHIIBHYY
that Schematic is no help at all and not even related to this Thread, I'm sure you will find this more helpful.
Also NOTE: as I stated before you can request the Braking option to be added by HuanYang
Question:Can I use a braking resistor on this vfd?
Answer:Discharging function is needed for mounting braking resistor on VFD. If you need to mount braking resistor, we can mount the function on the VFD we sell to you.
By Huanyang Electrical SELLER on December 7, 2017
Yes there Power module is similar to what we manufacture. you are going to see a lot more VFD Drives and Servo Drives with this new technology it's a much better control method, the only draw back is you can't just replace a chip, if you have a drive problem, you have to replace the whole power module, which will contain most of the main electronics MCU Etc these are an all in one package
For you lathe you should look at the Huanyang GT series
Mactec54
sorry I'm not late to the party, that pic I posted was just from Phil who posted back in 2011, and if you are so Knowledgeable then why did you post the wrong schematic in the first place, Why are you so Condescending, did some one treat you Badly.
I guess there is no point in me posting the FW dumps or the disassembly, along with the procedures to use ICEstick since you seem to think this is all so pointless, Now I know why I don't post here often to try help others. Best of luck to you.
It's not the wrong schematic, it has most of the same information on it, but not as clear, that is why you posted that schematic which he already had, I first posted that schematic in January 2011, it was copied by many others
Nothing is pointless, any information that has not be posted, is good information, even if it is not needed now, someone may need it for some other reason, I sure don't have everything, but I do have a lot of information on more than 60 different VFD drives
Mactec54
Hello.
The frequency converter broke for me - two phases were closed on the motor.
Could you share the electrical diagram on "VFD HY01D523B" ...
I would be very grateful to you .. (Sorry for my bad English language)
Mactec54
