Hello, i'm rebuilding a DM4400, and i want to replace the original driver for the spindle motor.
The spindle is a brushed DC motor.
Nameplate:
The original driver is 160V at 30A. I've been looking a bit around for users using the CNCdrive DG4S-16035 for spindle applications, but i cant seem to find much.
Does anybody have a recommendation on driving this spindle motor? I've also had a look at the Viper 250 H (230Vdc 30A)
The control signal is not that important.
Buget 500$
- G0704 Spindle bearing upgrade - Vertical play/slop on spindle shaft.
- Problem- C11T board - spindle 0-10v output wandering and causing inconsistent spindle speed
- Need Help!- Installed spindle power quick change, now my spindle is dead, need motor resistance
- Spindle motor set,1pcs 2.2kw spindle + inverter+ spindle mount bracket+ER collet
- Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code
