- How do i disassemble water cooled Chinese spindle?? Help... (pics)
Re: How do i disassemble water cooled Chinese spindle?? Help... (pics)
The rear bolt is left hand thread, unless you have the correct wrench to fit, you will damage the nuts the front nut you need a pin wrench, if you damage these parts you can through it in the trash, as you will mess up the balance of the spindle
The bearings are sealed so the water would not of got inside them
Hi Dm7g,
I changed my bearings and have pics if needed, but I used the thread below for reference, it's a 3kw but almost the same but a little larger scale. The 2.2kw should be a little easier because the left handed bolt on a 2.2kw no special tools needed.
Good luck,
Dan
http://www.cnczone.com/forums/spindl...er-cooled.html
- You may not post replies
- You may not edit your posts
Forum Rules
