Need Help! 3.7KW Spindle problem - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 65 of 65
Thread: 3.7KW Spindle problem
  1. #61
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: 3.7KW Spindle problem
    Quote Originally Posted by Yasser47 View Post
    OK, I lost my mind Already, I got another spindle today and tried it, Guess wht, GFT, again!!!!
    I will go now to get a braided shielded cable and try again and get back to u ASAP
    so the only remaining unchecked is the harness
    so on 24K (high frequency motor) spindles the lower the RPM the hotter it gets, the more stressful the motor gets, the higher the power consumed while in operation, so this is the reason why I only get 60-80 watts on my 1.5KW 24K RPM spindle because im running it @ full speed all the time
    another question raised, where the hell are they deriving the 1500W specification on the spindle motor? anyone? I know there are 3 types of HP but where did it belong? braking HP I guess?
  2. #62
    Mar 2017
    Egypt
    OK Everybody, Congratulations
    The Braided shielded Cable just solved the problem, thx a lot
    I have changed the cable and connected it as you told me and everything is OK, 30 min operation without a problem, I hope its the cable ONLY,,, I will continue tomorrow and tell u what happened
  3. #63
    Jun 2005
    Yasser47,
    Yup, but Mactech should get the BLUE ribbon he is the first one that spotted you failed to use shielded cable.
    Russ
  4. #64
    Mar 2017
    Egypt
    Quote Originally Posted by CNCMAN172 View Post
    Yasser47,
    Russ
    Whats the blue rippon?
  5. #65
    Jun 2005
    Cool Re: 3.7KW Spindle problem
    Yasser47,
    Sorry that is an American for the first place prize. This originated long ago when farmers held State Fairs, the winner for every given category was given a Blue Ribbon to signify they got 1st place in that given contest.
    Russ
    3.7KW Spindle problem-1st-gif
