Need Help! problem with Delta VFD-M Blinking red stop
Results 1 to 2 of 2
Thread: problem with Delta VFD-M Blinking red stop
    Apr 2016
    Default problem with Delta VFD-M Blinking red stop
    Hi I was just using my CNC and stopped my router to put on the dust collector on. When I went to start the router it wouldn't start. The red stop light is blinking. The screen says F0.00. isn't it supposed to say F600. Could this be the problem and how do I reset it to F600. Thanks
    Member mactec54's Avatar
    Jan 2005
    Default Re: problem with Delta VFD-M Blinking red stop
    Quote Originally Posted by PaulGB View Post
    Press reset/stop button and check that the VFD is in the right mode, that's not a normal fault, for these drives so something strange is going on
    Is your spindle Ground connected
    Mactec54
