Just one of the many on eBay:
FOUR BEARING 1.5KW ER11 65MM WATER-COOLED SPINDLE MOTOR ENGRAVING MILL GRIND CNC | eBay
Yes, 1.5kW is good for aluminium. I have one (air cooled 1.5kW 65mm) and it works fine. I don't think you will find a more powerful spindle at this diameter. One advice though... you should buy a more powerful VFD, that way if you realize the motor is not what you want you can just get a new motor. Note that the larger motors are also much heavier.
