The less expensive would be fine. Only connect the shield at the panel end to prevent a ground loop.
EDIT:
I didn't read the specs very well, you want to use the 4 conductor cable, to keep the safety ground isolated from the shield on the motor end. As above only ground the shield on the panel end.
