It sounds like you lost the output that turns on the VFD. Just to confirm that the VFD and motor are working, I would reprogram the VFD for keypad operation and see if it will run from there. If that works, then the problem probably in the BOB. I am assuming that you are not able to start the spindle manually from Mach3.
