Can't get Mach3 to Control VFD
Results 1 to 8 of 8
Thread: Can't get Mach3 to Control VFD
    Jul 2008
    Default Can't get Mach3 to Control VFD
    Hello to all.
    I have a Hitachi VFD, 2.2kw spindle and am using Mach3 with G540 and ESS.I set all the parameters for the VFD for manual operation and everything worked fine. Then I tried to set the parameters to control the spindle from Mach with PWM mode (no relays) but I can't get the spindle to spin. I'm getting the correct voltage from g540 to the VFD but the spindle does not move no matter what RPM I enter in MDI.
    Parameter changes from manual settings:
    A001 to 01
    A002 to 01
    Wiring is as follows:
    G540 pin7 to L terminal on VFD
    G540 pin8 to O terminal on VFD
    G540 pin9 to H terminal on VFD
    Am I missing any additional wiring or parameter changes?
    Thanks,'
    Nick
    Dec 2003
    Default Re: Can't get Mach3 to Control VFD
    Do you have a RUN signal input to the VFD inputs?
    This is output from Mach at when a M3 (spindle start FWD)
    Shorting bar from P24 to PLC.
    You should be able to go direct from the G540 to the Hitachi.
    See http://www.cnczone.com/forums/spindl...equipment.html
    Jul 2008
    Al,
    Shorting bar is there. If I'm understanding you correctly, I need a wire from g540 output to the vfd logical input 1 for the run fwd command. Is that right?
    Nick
    Dec 2003
    Two wires the Com and whatever the FWD input is set for in the VFD..
    Jul 2008
    That did it.
    Thank you Al.
    Aug 2012
    Quote Originally Posted by Al_The_Man View Post
    See VFD interface to other equipment.
    I have connected my Hitachi WJ200 to a G540 as you described. When I activate the spindle on Mach via M03 S24000 the spindle turns on but very slowly. The G540 output between pin 7/8 is only 0.1V and VFD displays 4hz (spindle goes to 400hz). I've configured the pulley/speed in Mach 0-24000 and the PWM output is 50hz base. Any ideas why I'm not getting 10V from the G540?
  7. #7
    Aug 2012
    I disconnected the G540 from Pin O of the VFD (0-10) and jumpered it to Pin H of the VFD (+10v). Works fine, spindle runs up to 24000 rpm via Mach3 control. I also checked the reference voltage at Pin O and it's 10.55V. So my problem seems that Mach3 is not telling the Gecko to run at the right speed or the Gecko is not outputting 10V properly. Any ideas?
  8. #8
    Aug 2012
    Figured it out. In Mach3 Ports/Pins config, the Spindle row had the dir pin, step port, step dir all set to 0. I changed them all to 1 and it worked! I started from the latest G540 XML file so don't know why that would be set that way (possible it changed for newer models, mine is about 5 years old).
    Working config screenshot attached:Can't get Mach3 to Control VFD-mach3spindleconfig-png
