Mach3 to VFD Spindle Speed and Control - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Mach3 to VFD Spindle Speed and Control
  1. #21
    Member mactec54's Avatar
    Jan 2005
    Default Re: Mach3 to VFD Spindle Speed and Control
    Quote Originally Posted by Rich2017 View Post
    I need the facing bit I will use to go Clockwise.
    You most likely then have to use a M4 and have that setup in your control, M3 is normally wired FOR
    Mactec54
  2. #22
    Dec 2003
    What about PD023 Should be set to 1 for rev run enable.
    Default is 0.
    Jan 2005
    Quote Originally Posted by Al_The_Man View Post
    Default is 0.
    Correct he would need to set that Parameter for reverse operation, the problem is Clockwise is standard and For connection, used with M3, so it looks like he has been running his spindle CCW which would be REV and M4
    He has some setup to change and may be some wire connections
    Mactec54
