"your 1.5Kw spindle will be 24,000 RPM @ 400 Hz they can not be run on 60Hz 100Hz=6000RPM"
ok I did not know this. I am going on my limited knowledge of these VFD's. I know some other VFD's run up to 60hz which = max RPM. I had assumed the 400 max readout = 50/60hz because the VFD default is 50hz. I will go through VFD settings again. I could change it to 400hz but I want to confirm there is no problem with the motor. My fluke is a lo-z meter so I figure I should be getting some kind of resistance and not what looks like a dead short.
