- Yaskawa 626-MT3 begins to run soon as forward run enabled with no analog speed input
I am finally making headway on my retrofit. Now as soon as there is a run signal the spindle goes to turning about 20 rpm. no orient signal, no analog speed signal, but it still runs. I have dug through the manual over and over. I thought it would be like the servo drives where there is a zero pot to get it to stop. I am still working on some things in my controller (Linux CNC) to get the control to handle the spindle correctly.
Any thoughts of getting this to zero out?
- You may not post replies
- You may not edit your posts
Forum Rules
