I'm gonna say you got an honest answer from the seller.
Hello guys
been looking for a 65mm (what my machine's bracket came with..) spindle. as far as I see, 1.5kw is the most powerful I can find at a 65mm diameter.
I asked a seller at Aliexpress about 65mm spindles and he answer:
Dear,
All 65mm spindle is 800W, some seller lies,
although they told 65mm 1.5KW but real power rate is 800W.
Best regards,
Yours faithfully,
Is that possible? any chance there isn't 65mm 1.5kw spindle?
thank you
Unless you go for something like an Alfred Jaeger...
Served by a Droid
I can find 65mm 1.5kw spindles online, then again, it may be only 800w?
The specs are often misleading. My HY inverter is labeled as 110V output 1.5KW 13A, but the parameters only allow an output current of 7A. Maybe it is really only 800W. I can live with this for hobby work since I used a 1HP Bosch Colt for many years and it was plenty of power.
Steve
