Newbie Huanyang hy02D223B or Askpower A131
Results 1 to 8 of 8
Thread: Huanyang hy02D223B or Askpower A131
    Registered nike_bytom's Avatar
    Oct 2016
    United Kingdom
    Question Huanyang hy02D223B or Askpower A131
    HI All,
    Recently I have bought 2.2kW spindle kit of eBay. I am a bit confused about my VFD.
    On the label is HY02D223B but inside it looks like A131? What you think guys?
    VFD works with default settings as it should. 400 hz is setup as maximum and 100 hz as minimum , I can control speed thru panel no problem.
    Yesterday I did try to connect 10k Pot for speed controlling.
    Following instruction i connect all the cables to correct terminals and change value in the setting to Pn 03 from 2 to 1.
    Now when i turned on my vfd lcd display was showing 100 and turning pot didn't change anything - do I need change some other settings as well to get pot working?
    Regards
    Attached Thumbnails Attached Thumbnails Huanyang hy02D223B or Askpower A131-2016-10-11-06-09-17_-jpg   Huanyang hy02D223B or Askpower A131-2016-10-11-06-09-30_-jpg   Huanyang hy02D223B or Askpower A131-2016-10-11-06-09-40_-jpg   Huanyang hy02D223B or Askpower A131-2016-10-11-06-10-04_-jpg
    Huanyang hy02D223B or Askpower A131-2016-10-11-06-10-11_-jpg
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Huanyang hy02D223B or Askpower A131
    Quote Originally Posted by nike_bytom View Post
    According to the A131 manual posted here on CNCzone, Pn03 should be set to 3 (external 0..5V).
    Oct 2016
    United Kingdom
    Quote Originally Posted by CitizenOfDreams View Post
    Thank you for the replay, so the option 1 is for the pot that is already fitted in to the control panel?
    Raf
    Nov 2012
    That is correct.
    1 - the built-in potentiometer
    2 - the built-in up/down buttons
    3 - external 0-5V input (which is where you have your potentiometer wired)
    4 - external 0-10V input
    5 - external 0-20mA input
    6 - serial interface
    7 - "multi-segment signal" - as far as I understand, you can program 8 different speeds and switch between those speeds using external buttons.
    Oct 2016
    United Kingdom
    Thank you very much,
    I will change the setting when I get back home.
    Do you think i can use Mach 3 plugin to control speed, if yes how i connect it to my PC
    Raf
    Nov 2012
    If your VFD has a serial control option, you can use RS485 Mach3 plugin. You will need a USB to RS485 adapter to connect the VFD to the computer.
    Another option is to use PWM control through 0-5V analog input. What kind of breakout board are you using?
  7. #7
    Oct 2016
    United Kingdom
    Hi
    I have hy-jk02-m breakout board as my main board, also i got second board fitted in my 'Driver Box' but is not connected is there in case I need it
    Also i have got RS232 to RS485 adapter.
    I have seen plugin for Mach but not sure how to connect VFD to RS485 adapter
    1st BOB
    2nd BOB
    Raf
    Attached Thumbnails Attached Thumbnails Huanyang hy02D223B or Askpower A131-20160929_200125_-jpg   Huanyang hy02D223B or Askpower A131-20160929_200141_-jpg   Huanyang hy02D223B or Askpower A131-cnc-breakout-board-st-v2-jpg   Huanyang hy02D223B or Askpower A131-hy-jk02-m-breakout-board-overview-jpg
    Huanyang hy02D223B or Askpower A131-20160929_200119_-jpg   Huanyang hy02D223B or Askpower A131-1475310151226_-jpg
  8. #8
    Registered diyhands's Avatar
    May 2017
    PN 04 set to #2
    DIY
