I will not be able to help with the wiring or parameter settings, but you need a little more info included. What spindle do you have?
What problems are you having that the default parameters will not do?
Since I posted this I found a youtube video that shows someone setting the parameters on a delta VFD-M at 1.5 kw and mine is a 2.2 kw. Does anybody know what parameters I need to change for mine? Hi- I just wired my Delta VFD-M to my 220 volt spindle. I see that there are many parameter settings and it says that they are set at the factory but some have to be set by the user depending on what spindle you are using. Can anybody tell me which of these parameters I need to change from the factory settings? Thanks
Lee
Hi Lee- thanks for the reply. The spindle I have is Chinese I believe. I purchased it from UGRA. Its a 2.20 kw/ 220 volt spindle. The problem I'm having is I watched a youtube video and set my parameters exactly like the video then realized the motor in the video was only 1.5 kw and I can't find the parameter to change for my spindle (2.2kw)
I am not certain, but it may not have that parameter.
If the VFD is sized accordingly, the actual rating of the spindle might not be critical.
Have you had to turning yet?
Lee
I haven't because I thought I might damage something if I started it and a parameter was set wrong. When I first wired the VFD to the spindle it rotated very slowly and I couldn't increase the speed. Since I set the parameters it doesn't spin at all
Good thinking I wish everyone did this, yes you can damage the spindle if your settings are wrong
Your VFD and any VFD is never set ready to Run, unless the supplier has preset the Parameters for you, which some times is the case
The main thing is you know what the Frequency of the Spindle is it 400Hz 300Hz, Amps we can work out Voltage we know number of poles we know, this is the only important information you need as these numbers are what have to be set in the VFD
Even though there are lots of Parameters that you see in the VFD, there are not many that you need to change
Mactec54
Its a 400 hz/ 9.70a spindle. I'm using Mach3 software for my CNC
Thanks so much. I'm a retired woodworking teacher that has been working on this for years
PaulGB
This will get you running, do the RESET First then set the Parameter in this list, some are Default so don't need changing, I will check if there is anything other Parameters to change later today, just take your time, it's quite easy once you get to understanding the keyboard
Mactec54
Pr.76=10 ( This is for Factory RESET )
Pr.00=00 ( 04 for Pot use )
Pr.01=00
Pr.03=400
Pr.04=400
Pr05=220v ( Default )
Pr.10=10 ( Default Adjust to suit Acceleration )
Pr.11=10 ( Default Adjust to suit Deceleration )
Pr.24=01
Pr.26=100
Pr.27=100
Pr.37=100
Pr.52=9 ( Max Amps )
Pr.148=02 ( Number of Poles )
( Auto Tune After these Parameters have been Set )
Pr.103=02 ( Auto Tune )
Mactec54
Thanks- I did those changes but I have 2 questions- Pr.00=00 (04 for Pot use) What is pod use and do I have it? the other question is Pr.08=20 when I put that number in it said ERR or error and wouldn't accept that number. Thank you again for your help i really appreciate it.
The pot is the knob you turn on the front where the Keypad is, if you don't have it then leave it at Pr,00= 00, some the Pot will still work when set at Pr.00=00 if it does not work then change it to Pr.00=04, the Pr.08=20 can also left at the ( Default Pr.08=1.5 ), this setting is reliant on other settings, so just leave it at default, it won't affect how it will run, I will remove the Pr.08 from the list, it made an error because another parameter needs to be set also, and you don't need the other parameter set
Mactec54
IT WORKS! Thank you so much for your help. You have no idea how many sleepless nights I had trying to figure it out. Thanks again and good luck to you!
Thanks- I changed Pr-52 to 9 and I have Pr00=04
