Newbie FC300 inverter
Results 1 to 4 of 4
Thread: FC300 inverter
    Aug 2015
    Default FC300 inverter
    i just bought an fc300 2.2 kw inverter but i cant control the spindle speed on my desktop.but the rest of the commands such as on off spindle and M05; works fine . ive posted a copy of the manual maybe you can help me out with the parameters.thank you
    Attached Thumbnails Attached Thumbnails FC300 inverter-wire-jpg   FC300 inverter-english-manual-pdf
    I just gotten one recently and while I am able to turn it on and off through mach3 I am having difficulty with controlling the spindle speed.
    I am using gecko g540, ess from warp9 running with mach3.
    So far one issue is no 10v output from pin 8 of g540 though the vfd does give 9.6v to pin 9 of the g540.
    Has anyone sucessfully configured the fc300? 2.2kw water cooled
    Quote Originally Posted by timber715 View Post
    Help anyone?
    Sep 2017
    Default Re: FC300 inverter
    I have just bought the same set up, are you running Mach3?
FC300 inverter
FC300 inverter
