- Weak bearings
Weak bearings
I need a PDF file for a 5.5 HP Colombo spindle. The bearings are at the end of their service life and I have a pretty good machinist lined up to replace them but he needs a PDF file to see the correct disassembly/assembly sequence. I can't see to find the right site on line.
CJ
Re: Weak bearings
just take a picture as you removing part..
all part you remove..
Re: Weak bearings
Which "typo" is your 5.5HP Colombo? Is it an RS90, RV90, something else?
- Weak bearings
- You may not post replies
- You may not edit your posts
Forum Rules
