Mach uses a PWM signal for spindle control, for spindle controllers that have 0-10vdc analogue control, a convertor from PWM to analogue is required.
There is also Modbus if the controller is capable.
So, i am starting to search some good spindle to my 3 axis machine ( want to start machining metal ) and i have some doubts about it, like, can i control the speed of spindle and inverter combo in mach3 ? if not how can i use powerful spindles that can have the rpm controlled in g-code ? ( like 1 kw spindle or less, minimum 600w ), i only know the basics about eletronics, i am just finishing my mechanic technician course, so can someone give me a fast-learning about mach3 speed control ?
- Newbie- Why are keling ATC spindles so much more expensive than er11 spindles?
- Any reasonably priced (cheap) spindles other than the chinese spindles?
- Starting out and would like OneCNC XR4 Mill (Professional or Expert)
- Spindles de alta qualidade.High quality spindles.
- Search Function Not Working On Xylotex Fourm And Main Search
A professional spindle is one that uses a servo.
A step/dir spindle will work fine.
You should use a hw pulse generator, and a suitable servo.
i could use servo motors in the future, i dont have that type of knowlegde and money, as i have searched in ebay spindles with pwm control, they reach up to 400w only, maybe 600w, so with that in mind, could be better i use i dont know a spindle with converter, and if i need to change rpm in the middle of a program i make a obrigatory stop with a message text saying the rpm i should set them cicyle start again ?i have done a obrigatory stop once yesterday just for testing and worked
There are pro-grade spindles for routers that aren't servos. Servo loops are only required for operations like rigid tapping, which need to synchronize the revolutions of the spindle with movement of an axis (usually Z), and they are used on mills, not routers. Pro-grade routers usually have a combination of a 3-phase router motor and a Variable Frequency Drive (VFD), which controls it. Some VFDs will also convert single-phase power to 3-phase, and can vary the speed using input from your machine controller. Hitachi makes VFDs that I've had good luck with. For the router/motors themselves, look for brands like Perske, Colombo, and Elte.
Have you looked at ViperServo website
2,3 and 7Hp spindles Perske Tekmotor and Colombo spindles are in stock.
Larry
