I can read. Base is not minimum.
It is stamped on the spindle Name plate that Base is 18,000 RPM @300Hz and at 400HZ Max is 24,000, can you not read, I don't think it can be any clearer than what is stamped on the name plate
The 4147 model # is on there web site, you just need the rest of the number to find the spindle
All we need to no to be sure, is if it is a SB series or a DB series
Mactec54
Hmm. Can you link to where Teknomotor say that? I would have thought they would have called it "min frequency" or something like that, because base frequency means something else in the HF spindle world.
Other than where it says "Base Frequency", where does it give a range? The only ranges I saw were what I posted before. As I said, in their catalog, for the model # on his spindle plate (4147), it says either 12000-18000, or 12,000-24,000. Both of these ranges are for air cooled spindles with shaft driven fans.According to there web site it is, they give the range
Yet you continue to say that their website has different info. Although you seemed to almost agree with me for a short time, before going back to the 18-24 range.
Give us a link to this data.
UCCNC 2017 Screenset
I posted that before, you need the series number, the model number is not much use by it's self, from that you will know what spindle he has, it can not be what you are staying 12,000 to 18000, because they would not have 24,000 Max stamped on the motor plate,so it will be one of the DB series spindles, but without all the numbers everyone is just guessing as to what the slowest RPM the motor can do
Mactec54
Yes, We're guessing. Then you say we're wrong, but you have nothing to back it up. That's all.
Who ever is saying it is a 12,000 to 18,000 is wrong for sure, that would be the SB series & it is not the SB series spindle, only the DB spindles are 24,000, the only thing that is missing is, does it have a max minimum of 12,000 ???? or a max minimum of 18,000???? this will depend on the part numbers of the spindle
Mactec54
naspc
If you use these numbers they are correct, for your spindle, it has no minimum speed,(For your Spindle) if trying to use it to slow it will have no torque,& stall, so it will not be of much use below 130Hz
These are the main settings to get you going
P304= 400
P167= 300
P103= 400
P102= 130
P302= 220
P303= motor amps on the name plate
P104= 20 adjustable Accel
P105= 20 adjustable Decel
Mactec54
Thanks Mactec54. Dont know if you read my mind or something but I just called the place where I got the spindle for answers. The connection was bad, expecting a call back form them.
I dont mind running it at high rpms. I was thinking of doing aluminum milling and somewhere I read that milling aluminum should be done at a lower rpm.
But after seeing a couple of videos of other people with Teknomotor spindles milling aluminum at 16000-18000 rpm, I am confident this spindle will do the job.
Hopefully in the following weeks I will have a VFD to hook my 4147 Teknomotor spindle to. I will try and fill in the blank left open by the original poster.
Thanks everyone for chiming in.
naspc
There is not much else you have to set, what I posted will be enough for running your spindle, you have to also run it in, starting at 3,000 RPM for 2 minutes increasing it by 3,000 every 2 minutes, watching the temperature does not go over 50deg C, if it does you stop the spindle let it cool down then start again at the last setting (RPM) it was running at
Mactec54
The vender that sold me the spindle confirms what Mactec54 has posted. Not that I didn't believe you Mactec54, but out of courtesy he called me back.
So the safe min the spindle should run is 18000. But it can run slower but may over heat, seems like the fan is dependent of the rpm of the spindle. Also anything below 18000 the torque may be insufficient.
Hey all, finally got a lenze vfd. The same one in this post. I am about to connect power to it. I am using a 30amp turn lock connector and cable. I know the green wire (ground) goes to PE. However the other two wires I not sure of. I have a yellow and a black. Where would these 2 go? L1 and L2?
Thanks. Should I program the vfd with the values from before I connect the spindle?
Ok. Configure vfd. Power vfd off. Wait for vfd discharge. Connect spindle. Power vfd on and test at 2k intervals for 2 minute each 2k.
Hi all,
Just an update. I used the recommended setting for My VFD and Motor. And everything looks good. Motor is moving nothing on fire (Yet). I just have an issue with setting up the Potentiometer.
P304= 400
P167= 300
P103= 400
P102= 130
P302= 220
P303= 8.6
Additional Settings for Terminal Strip and Dynamic Brake:
P100=1
P101=1
P121=21 Dynamic Brake
P122=11 Start Forward
P142=24 Dynamic Brake
