pc 50 GIDDINGS & LEWIS 16i
TENGO UNA MAQUINA G & L DE 5 EJES LA CUAL EMPEZO A TENER PROBLEMAS DE VIBARCION EN LA MESA ROTARIA Y EMPECE A BUSCAR LA RAZON CUANDO LA ENCONTRE QUE EN REALIDAD FUE QUE UNA CUñA DEL MOTOR DEL EJE B TANIA JUEGO Y LA BANDA ESTABA MAL SE CAMBIARON Y A PROBAR PERO EL ENCODER DE LA MESA YA NO QUISO TRABAJAR DECIA QUE NO TENIA CONECCION ASI QUE LO CAMBIE Y YA PUDE MOVER EL EJE PERO AHORA VIBRAVA CON MASA FUERZA ASI QUE ME PUSE Y REVISE EL ELCODER QUE ME MANDARON COMO SUSTITITO DEL ORIGINAL Y NO SON IGUALES EL ORIGINAL TIENE
encoder original es rcn 220 1048576 pulsos por rev
El encoder nuevo rcn 223F 8388608 pulsos por rev
ASI QUE LA RESOLUCION NO CONCUERDA CON LOS PARAMETROS ESTABLESIDOS ASI QUE BUSQUE COMO CAMBIAR ESTO Y ENCONTRE LA PAG SIG
http://www.cadfamily.com/download/pl...65270EN_01.pdf
en la seccion 2.1.4 dice como calcularlo pero no le entiendo
DEFINITION OF WARNING, CAUTION, AND NOTE................................ s-1
1 OVERVIEW ............................................................................................1
1.1 SERVO SOFTWARE AND MODULES SUPPORTED BY EACH NC
MODEL ..........................................................................................................2
1.2 ABBREVIATIONS OF THE NC MODELS COVERED BY THIS MANUAL....3
1.3 RELATED MANUALS....................................................................................4
2 SETTING i SERIES SERVO PARAMETERS ......................................6
2.1 INITIALIZING SERVO PARAMETERS..........................................................6
2.1.1 Before Servo Parameter Initialization ..................................................................... 6
2.1.2 Parameter Initialization Flow .................................................................................. 7
2.1.3 Servo Parameter Initialization Procedure ................................................................ 8
2.1.4 Setting Servo Parameters When a Separate Detector for the Serial Interface
Is Used ................................................................................................................... 18
ALGUIE LE ENTIENDE O QUE YA LO HALLA ECHO ANTES
PARAMETROS
2024 26
2084 9
2085 2
FELIPE@PERSAL.COM.MX
