SouthWest Region
Threads 1 to 11 of 11
Forum: SouthWest Region
SouthWest Region club house.
  1. Smile USB TNG script, trying not to reinvent the wheel.....
    Started by dakman‎, 08-30-2017 12:04 PM
    axis, block, software, tng, tool
    08-30-2017, 12:04 PM Go to last post
  2. Newbie- Need help:drowning:
    Started by skatstuff1‎, 03-06-2017 08:38 PM
    cnc, limit switch wiring, router cnc, software, t-d controller
    03-06-2017, 08:38 PM Go to last post
  3. Irregular rotatory chine machine
    Started by JS1025‎, 12-02-2016 01:30 AM
    12-02-2016, 01:30 AM Go to last post
  4. building a CNC Router cable
    Started by kc5jmr‎, 08-02-2016 09:36 PM
    axis, cnc, monitor, question, router
    11-13-2016, 03:34 PM Go to last post
  5. Need Advice- lead screw jgro plans.
    Started by captainlee‎, 09-13-2016 10:40 PM
    jgro, lead, plans, rod, screw
    09-14-2016, 04:35 PM Go to last post
  6. Need Help!- Want to post-process x axis to a axis
    Started by chucktilbury‎, 07-29-2016 06:50 PM
    axis, cnc, couple, inkscape, working
    08-27-2016, 11:26 AM Go to last post
  7. Red face Limited budget, looking to get a new machine
    Started by DUBIAROACHES‎, 11-03-2015 05:36 PM
    budget, cnc, machine, size, top
    02-15-2016, 01:05 PM Go to last post
  8. Need Help!- Yuasa Microstar N1 CNC Lathe
    Started by notchtopper‎, 07-30-2014 07:37 PM
    02-14-2016, 05:58 PM Go to last post
  9. Need Help!- Z-Axis Tool Path is Higher than Z-Axis Zero
    Started by mike0866‎, 09-03-2015 12:13 PM
    cnc, cut, software, tool, z-axis
    09-03-2015, 01:09 PM Go to last post
  10. Need Help!- My new machine Nema 23s
    Started by Garysb‎, 05-30-2015 08:03 PM
    hot, motor, motors, nema, running
    05-30-2015, 08:03 PM Go to last post
  11. Need Help!- FANUC Series oi-TD Lathe
    Started by schmixter‎, 05-28-2014 06:34 PM
    05-28-2014, 06:34 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
