Could it be a problem with your keyboard? Have you tried plugging in another one?
I need help with my cnc . I builted mine and it has been running very good. I am running Mach3 & cambam . I st started to have a problem with the z axis I can't zero the zaxis it will go down but it won't go up when I manual
try to move it up I can't use the key board or the remote the z axis works fine when I run a program to cut something . Is there anyone that can help?
hit the tab button and make sure the jog feature is in cont and not step. That is normally what happens to me. It makes you think it isn't working, but you are only telling it to move whatever the step is set to.
