3000USD for a cnc router? You need the show us the specifications they give you, then it will be easier
I have $3000 to spend on a cnc router. Looking at Romaxx, Stepcraft or Shapeoko 3. Give each your opinions and reasons.
Why not build yours?
i have invested around 1900 on mine and its about 36x36 running a 2.2kw air cooled spindle and it works great
The first CNC router I made, just wasn't accurate enough. I need an accuracy of .005 minimum. I'm looking at a Romaxx HD-1.
I have looked at XCarve, and Shapeoko, and a few others, but the problem is when the z axis is lowered, there seems to be
some reflection (deflection), and the router and z axis tend to be not stiff enough for accurate depth engraving and routing.
I will be engraving aluminum, pewter, sterling, and some gold. I will then be routing wood, and some aluminum.
If I thought I could be assured of an accuracy between .002 and .005, I would build my own again.
Maria
What are you looking to cut? There are folks out there that can build for you what you need at your budget.
Slow work takes time
www.facebook.com/Bear-CNC
