Where are you? I am in the Conroe area.
newbie running mach 3 with a 6040 cnc router
A lazy man does it twice.
Hi I am in Bridgecity near beaumont texas
Zcar, I have never run a 6040 but have run many other types of 2-3 axis machines on Mach. Need some help?
Hey Bud thanks for reply
Yeah I really need some help to have this machine going it uses Mach 3 . And I don't have any experience with this
Using Tapatalk
Check your messages
I'm in Sugar Land (southwest Houston). No CNC as yet but planning...
anybody in spring that could help me set up a mill for mach 3 and a ethernet smoothstepper? im so lost on what i should be doing to configure
I have a 6040 router. Just replaced a couple major things. Since the Chinese manufacturer decided not to cover their one year warranty. Never again will I buy any thing from china again. 1.5kw watercooled spindle burnt up after 4 months and y axis ball screw bearings fell apart. $248 local for the bearing assembly. Bought two from china for $50 seems to be holding up. Anyway if you need some help I can help.
Sure. Check your messages
Basselete, did you ever work thru your issues?
